Thanks for coming back to me, I dodnt see the post earlier.
I guess it is a little hard to explain in words but I will try below. I will put together a screen shot in the next day or two and come back to you also.
Currently, in the ‘top’ position, I have a module ( standard ) that is a put xhtml module with no borders, rounded etc. Ans it takes up 100% of the available template width.
Below that I have the user module ( 1-5?) available – but I am not using..
Then below that i have Left – Content – Right with the column width set with “$this->_basewidth = 23;”
What I want is:
Top Left – Top – Top Right
User
Left – Conent – Right
User etc..
Where the %width for the top left and top right are taken from the same variable as the main right and left values ( if possible ) and can be styled with the same _hilite etc suffixes from the template.
Does this make sence? 🙂 I hope so, but as I said I will also create a image with a screen shot of what I am after, but can do it right now.
Again, many thanks for replying
Michael Tull
