  • charles99 Friend
    #164986
    I seem to have a problem adjust the right column width. I made the change in the template manager but it is not adjusting to the new percentage I made. I would like to know has the process changed & how do I go about reducing the right position or column width?
    Right now its set at 33 I would like to reduce it to 28…
    Also I am getting the following megamenu error…
    Uncaught TypeError: Object #<Object> has no method ‘getElements’
    jaMegaMenuMoo.Class.startjsbf6c5.js:44
    b.i.extend.$ownerjsbf6c5.js:7
    jaMegaMenuMoo.Class.initializejsbf6c5.js:44
    (anonymous function)jsbf6c5.js:11
    a.Class.Type.g.$constructorjsbf6c5.js:7
    kshama_k Friend
    #395710
    hi charles99
    plase send me url and admin access of your site via pm. I will check it.
    and also refer this link: http://wiki.joomlart.com/wiki/JA_Template_Framework/Navigation
    luisvillamarin Friend
    #395905
    In what file you made those changes to the right Column? I’m trying to make changes as well so I have more room for my articles. I need to have at least 495 px to fit in some table I’ve design for previous template and I’m no looking forward really to make changes to the tables I added to the articles.
    Thanks in advance.
    kshama_k Friend
    #396020
    hi
    you can make changes in layout.css for right column width.
    /* Left Column —*/
    #ja-left .ja-l2 .ja-left1, #ja-left .ja-l2 .ja-left2 { width: 50%; }
    #ja-left .ja-l1 .ja-col { width: 100%; }
    /* Right Column —*/
    #ja-right { float: right; }
    #ja-right .ja-r2 .ja-right1, #ja-right .ja-r2 .ja-right2 { width: 50%; }
    #ja-right .ja-r1 .ja-col { width: 100%; }
    or inspect the right column, find the css for right column , try to change the width of this column
    and also refer this links for more help:
    http://www.joomlart.com/forums/topic/column-width-problems-2/,
    http://www.noupe.com/css/9-timeless-3-column-layout-techniques.html .
This topic contains 4 replies, has 3 voices, and was last updated by  kshama_k 13 years, 6 months ago.
