sandman1979 Friend
sandman1979
- September 2008
November 17, 2012 at 7:17 am #182329When i activate JA WALL, several functions/ menu’s in my agora forum are not working anymore. Like the searchfunction is not accessible, and when you try to post st, you cannot click on the smiley’s button etc.
seaneo Friendseaneo
- December 2009
- 12 times in 1 posts
November 19, 2012 at 3:39 am #473352Im not a moderator or support, but Agora forum for Joomla seems to not even be close to being responsive, hence it is not guaranteed to work with JAWALL
sandman1979 Friendsandman1979
- September 2008
November 19, 2012 at 12:05 pm #473446well when i use ja social for the forum only i still have the same issues, or sometime the whole template from ja social is goen when used for agora forum if the rest of the site is using ja wall….
seaneo Friendseaneo
- December 2009
November 19, 2012 at 8:05 pm #473497Agora forum is not even a Joomlart product is it? Combine that with the non-responsive nature of Agora forum, and you have a recipe for pain on the wall:) Just my observation – I am not a moderator or support
- September 2008
November 19, 2012 at 8:11 pm #473500it works fine with another joomlart template, but even when i apply the other template to the forum and ja wall to the rest of the site it is not working -> no good
Luna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
November 20, 2012 at 10:45 am #473607<em>@sandman1979 346975 wrote:</em><blockquote>it works fine with another joomlart template, but even when i apply the other template to the forum and ja wall to the rest of the site it is not working -> no good</blockquote>
Hi, JA Wall is a responsive template, and it’s quite complicated, not a simple one. It includes quite a lot of CSS and JS files. I suspect the JS in JA Wall has conflicted with the JS of Agora Component.
Agora is using JQuery library. I suggest you use firebug to check on the conflict.1 user says Thank You to Luna Garden for this useful post
- September 2008
November 20, 2012 at 2:36 pm #473627I just found a a solution myself.
Jvitals, the makers of the agora forum has made a free plugin available at their website: http://www.jvitals.com/extensions/free-downloads.html?task=default.product&id=9&cat_id=1
it can fix conflicting javescripts 🙂 It helped me out 🙂
1 user says Thank You to sandman1979 for this useful post
This topic contains 7 replies, has 3 voices, and was last updated by sandman1979 12 years, 1 month ago.
