January 21, 2014 at 9:49 am #193931
I use joomla 2.5 with JA Brisk + Framework 2.0.1,I have problem on a login extension, when I install below login extension :
http://improvedajaxlogreg.demo.offlajn.com/AJAX-Login-Register/default-flat.htmlin chrome and firefox everything works fine but in Internet Explorer it does’nt show correctly (Popup Login), I use IE v.9.
Can anybody help me ?
Saguaros ModeratorSaguaros
January 22, 2014 at 3:41 am #519328Does it work with default Joomla template? (you can try to switch default template to another standard template of Joomla like Beez)
January 22, 2014 at 6:48 am #519346Yes,
it works with other (default joomla) template.Saguaros ModeratorSaguaros
January 23, 2014 at 1:24 pm #519524Please take a Backup of your site and update JA Brisk template and T3 framework to the latest version. Then if problem still persists, you can PM me admin and ftp account of your site, I will have a look at this.
January 26, 2014 at 5:46 am #519845I change my login extension.
January 26, 2014 at 2:51 pm #519858Oops, I am exhausted.
I update the JA brisk and framework to the last version.
I use cb (community builder) login module, when I install the google+ plugin on it, in internet explorer v9 the slide show gone !!
I have a same problem on some other module before, but I think it was from module, now I don’t think so
I check it on 2 site with JA brisk it has problem, but with other theme everything works fine.
remember this problem just exist on IE.
you can see the sample http://mikrotikmum.com/ja2
what should I do ?Saguaros ModeratorSaguaros
January 27, 2014 at 1:25 am #519902I try to open your site in IE browser and the slideshow still works fine: http://prntscr.com/2mx9sn
January 27, 2014 at 6:35 am #519955I check IE v.9.0.8112 in 5 pc and it still not working,
as you can see in attachment, from the arrow in 1’st picture to 2’nd arrow in next picture is empty.
could you please check your IE version and tell me, and maybe it need some add-on or something like this !?-
January 28, 2014 at 7:43 am #520171Your site access seems to be restricted for member only, could you PM me an account so that I can check again in another PC?
Also try to check our demo site: http://joomla-templates.joomlart.com/ja_brisk/index.php/en/ at your end and let me know if problem still persists.
January 28, 2014 at 8:58 am #520180Sorry, For security reason I enabled the protection, right now it is disable,
Please check again, and remember in IE v.9 and prior problem exist.January 30, 2014 at 5:56 am #520459no answer, no body ?
February 3, 2014 at 5:45 am #520895I am still waiting for your response.
February 3, 2014 at 1:44 pm #520946Sorry for the lateness, I see the JS error when viewing your site. If possible, PM me admin and ftp account of your site, I will debug the code to check what’s wrong here.
Viewing 13 posts - 1 through 13 (of 13 total)This topic contains 13 replies, has 2 voices, and was last updated by Saguaros 10 years, 8 months ago.
