December 12, 2016 at 9:15 am #993774
Hi I have a problem when enabling template AJAX. I have installed some 3d party plugins (Regular Labs Sliders, map) and the template does not function properly
e.g go to http://dev-centiva.com/bach-sl-dev/products-en/fire-curtains/37-superfire.html the plugin (slider) is not displayed well formed but when you refresh the page everything is ok. The same at http://dev-centiva.com/bach-sl-dev/distributors.html The above page has a map in it but it only shows it on refresh.
Moreover I need a way to make the (medium) responsive view as the large one
Thanks in advance
- November 2014
- 3854 times in 3563 posts
December 13, 2016 at 5:16 am #994114Hi,
If possible, you can give me the screenshot and description on that. I will help to understand the problem on your site
December 13, 2016 at 11:15 am #994263Please check the attachments.
Its not a problem only to that, I have the same problem (correct on refresh) in that page too
http://dev-centiva.com/bach-sl-dev/distributors.htmlchech the above page and the refresh it
what about the following one
Moreover I need a way to make the (medium) responsive view as the large oneThanks in advance
Ninja Lead
- November 2014
December 14, 2016 at 10:49 am #994578Please try to navigate from the menu Products –> Fire Curtains and the open superfire
Moreover try from the menu DistributorsNinja Lead ModeratorNinja Lead
- November 2014
December 15, 2016 at 12:37 pm #994854Please do the following steps
- Open browser
- Open http://dev-centiva.com/bach-sl-dev/
- From the menu navigate Products –> Fire Curtains and then open superfire
Please its urgent
(I can send you a video if you cant reproduce it – I have checked it with different browsers)Ninja Lead ModeratorNinja Lead
- November 2014
December 15, 2016 at 4:22 pm #994900Hi,
Please give me the video with the problem on your site and the browser to get this bug. Besides, I double checked and clear cache my browser again but I could not produce your problem at my end
carlfarring Friendcarlfarring
- June 2012
December 29, 2016 at 8:14 pm #998255Ninja, the problem is that the Masthead Module position is supposed to be fixed and never change its position, only the right side should scroll. However, on his site when you visit the link provided the entire page scrolls including the masthead position.
James
- November 2014
December 30, 2016 at 4:54 am #998388@carlfarring: Thanks for your response but I did try to follow the steps above but the masthead still keep sticky when scrolling the right column. I can’t see entire page scroll up.
brusamolino Friendbrusamolino
- January 2009
- 10 times in 2 posts
January 4, 2017 at 3:04 pm #999558Hi
i have the same problem… have you found a solution?Ninja Lead ModeratorNinja Lead
- November 2014
January 5, 2017 at 2:49 am #999731This reply has been marked as private.brusamolino Friendbrusamolino
- January 2009
January 5, 2017 at 4:10 pm #999960hi
how can i fix it?thanks
- November 2014
January 6, 2017 at 6:37 am #1000144@brusamolino: Please give me the URL of your site here and let me know the browser are you using to check this bug? I will check further
- January 2009
January 6, 2017 at 11:37 am #1000258This reply has been marked as private. -
This topic contains 15 replies, has 4 voices, and was last updated by Ninja Lead 7 years, 11 months ago.
