March 23, 2007 at 8:34 pm #119316
i was able to download the JS Shopping II website and upload it on my website but when I enable the right menu its all messed up when seen in Internet Explorer, not Firefox. For some reason its not aligning properly the items in the right column. you might want to take a look at where I have the template here…http://www.tropicanaswimwear.com/
The right column is completely to the bottom of the page. Once again, it shows properly in Firefox but not in Internet Explorer. I am sorry but I am not a programmer to fix this. Could someone tell me where the problem is in the code so I can have someone figure it out??
SteveMarch 28, 2007 at 5:12 pm #216733I have the same problem but with Internet Explorer 7 is ok. The problem is Internet Explorer 6.
Any suggestion.
thanks
March 28, 2007 at 5:45 pm #216738I can tell you that most likely it is one of your modules that is published to the home page. I would suggest disabling each of them one at a time to find the offending module and then go from there. I have the same problem with the SMF Forums Login module. It does what you describe when that particular module is published in the Left menu. Then entire left menu gets pushed all the way down to the bottom of the page.
I still haven’t figured out how to fix it yet but at least I now know which module is causing the problem.Hope that helps you some.
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
March 29, 2007 at 4:47 am #216782You could try to unpublish the module “Latest Swimsuits” or reduce the size of images used in that module.
Another solution is set your site screen to wide and disable the Screen chooser tools.April 3, 2007 at 5:26 am #217156<em>@buddha327 10668 wrote:</em><blockquote>Hi,
Steve</blockquote>Hey looks like you got it to work… did you figure out what the problem was? I’m still having the same problem… thanks!
note – widening is not really an option for me. Please help, thanks!
April 8, 2007 at 4:03 am #217465Temporal Solution!! :confused:
The module problem in my site is the Login form. I install Joomlashack Flexible Login Module http://extensions.joomla.org/component/option,com_mtree/task,viewlink/link_id,1444/Itemid,35/
This “Flexible” replace the Login Form, but I don´t change position or size of my module, its look identical
Now, with Internet Explorer 6 the left panel is ok.
Buuuuuuuuuut >:(
In narrow screen (Villadi template) the problem is present then I set default screen to “wide”
“To choose which screen’s width you want to use, go to the 24th line of the “ja_villadi/index.php” file and change the value of $ja_width_default to ‘wide’ (1024×768), ‘narrow’ (800×600)”And other problem… with JA Collapsed Modules, the Flexible Login Module don´t work :((
Temp Solution 😮
My english is poor (sorry)
April 11, 2007 at 1:03 pm #217699i got same aligment problem and have tried to remove all modules then the main pape fall down. have tried all modules one by one and all falls down???
what to do?
pleas help!!!ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
April 11, 2007 at 11:01 pm #217727kimona;12371i got same aligment problem and have tried to remove all modules then the main pape fall down. have tried all modules one by one and all falls down???
what to do?
pleas help!!!Can’t see any problem to diagnose without a live URL to look at sorry 🙂
June 25, 2007 at 4:35 am #222660<em>@whouse 11129 wrote:</em><blockquote>I can tell you that most likely it is one of your modules that is published to the home page. I would suggest disabling each of them one at a time to find the offending module and then go from there. I have the same problem with the SMF Forums Login module. It does what you describe when that particular module is published in the Left menu. Then entire left menu gets pushed all the way down to the bottom of the page.
I still haven’t figured out how to fix it yet but at least I now know which module is causing the problem.Hope that helps you some.</blockquote>
hey I am having the exact same issue withe the smf forum login……anyone know how to fix this?
)JK
This topic contains 9 replies, has 8 voices, and was last updated by yuccalab 17 years, 6 months ago.
