  • zombie65 Friend
    #140815
    I upgraded to IE 8 and know my alignment is off. JA-Purity was working flawlessly until I did this.
    I can’t seem to upload any screen shots to better describe my problem.
    My categories now align to the left, the right colum also shifted left.
    Everything is ok with different templates, so I’m pretty sure it’s a CSS problem.
    I’m running Joomla 1.510
    VirtueMart 1.1.3
    Agora 3.0b
    http://www.thunderkissnw.com
    Thanks for any help you can provide.
    zombie65 Friend
    #304219
    Anyone?
    My site is going live within a few days. I’d appreciate any kind of help.
    Here is the screen shot.
    1. screenshot
    grupogw Friend
    #309195
    I guess it’s a little over my head as well, but at about line 67 in index.php of the purity template you will see where it says greater than or equal to IE7:
    <blockquote><!–></blockquote>
    I changed this to just equals IE7 as Dolfa suggested:
    zombie65 Friend
    #309203
    Worked like a charm, thanks 🙂
    johnsamuels Friend
    #332209
    <em>@grupogw 134376 wrote:</em><blockquote>I guess it’s a little over my head as well, but at about line 67 in index.php of the purity template you will see where it says greater than or equal to IE7:
    I changed this to just equals IE7 as Dolfa suggested:</blockquote>
    That worked great grupoqw, thanks given.
    dkmortensen Friend
    #332523
    Thanks for the suggestion. Changing from
    to
    fixed it for me too.
This topic contains 6 replies, has 4 voices, and was last updated by  dkmortensen 14 years, 9 months ago.
