March 21, 2016 at 8:39 am #902734
each article will be assigned it’s own image.
Please help me to achieve this , thanks a million
Zamri
March 21, 2016 at 9:17 am #902767Hi
Your question is not clear , kindly provide complete description of issue with site details so i can help u in this case .March 21, 2016 at 2:04 pm #902914Pankaj Sharma ModeratorPankaj Sharma
March 21, 2016 at 2:33 pm #902918Kindly post url of the article page here .
March 21, 2016 at 2:57 pm #902930Pankaj Sharma ModeratorPankaj Sharma
March 21, 2016 at 3:06 pm #902934Hi
Image already using the max size of it and use 100% width , Also it can be goes out of the container width. As the 100% width work on the parent container width .
http://prntscr.com/ai2qmsHope its clear now .
March 21, 2016 at 3:20 pm #902939thank you for the explainantion.
How about I want to use "if then statement" where an element only appear in article pages only
example file /home1/hhmanu/public_html/v2/templates/purity_iii/tpls/corporate.php
<!DOCTYPE html> <html lang="<?php echo $this->language; ?>" dir="<?php echo $this->direction; ?>" class='<jdoc:include type="pageclass" /> <?php echo $resClass ?>'> <head> <jdoc:include type="head" /> <?php $this->loadBlock('head') ?> <?php $this->addCss('layouts/corporate') ?> </head> <body> <?php if article page only... then ?>Show this<?php end if ?> <div class="t3-wrapper corporate" style> <!-- Need this wrapper for off-canvas menu. Remove if you don't use of-canvas -->
how can I achieve this? thank you
March 21, 2016 at 3:24 pm #902941Hi
if you want to add something on article page , you can do custom work in the article layout file directly rather then in the blocks file .
Here is path : /purity_iii/templates/purity_iii/html/com_content/article/default.php- I suggest you to hire a developer for such personal custom work requests .
March 21, 2016 at 3:31 pm #902945thanks again for the explaination. Great help. I will try look at the file.
AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 8 replies, has 2 voices, and was last updated by zamrisafar 8 years, 9 months ago.
all articles need progressive image width 100% between menu and article body
