  • alioztr Friend
    #135495
    i have a problem look like this picture. Registiration area and all going under the video window
    what must i do.
    Anonymous Moderator
    #279624
    Dear alioztr,
    Please login to Administrator, go to Extensions -> Plugin Manager , edit Content – AllVideos Reloaded plugin, select Flash display mode to opaque or transparent. I think current the Flash display mode is window.
    Hope it helps.
    alioztr Friend
    #279744
    nothing changed :((
    Anonymous Moderator
    #279751
    Dear alioztr,
    could you please provide me your live URL?
    Anonymous Moderator
    #279846
    Dear alioztr,
    <blockquote>Please login to Administrator, go to Extensions -> Plugin Manager , edit Content – AllVideos Reloaded plugin, select Flash display mode to opaque or transparent. I think current the Flash display mode is window.</blockquote>
    I saw that you didn’t change according to my guide.
    When i viewed source of webpage, i saw that wmode of Flash is also window value.
    Please check again.
    Anonymous Moderator
    #279851
    Dear alioztr,
    I fixed this issue.
    Please check again.
    alioztr Friend
    #280012
    Thank you.
    Can you say that how can you did it.
    Anonymous Moderator
    #280072
    Dear alioztr,
    I changed wmode of Flash to transparent value.
    Please feel free to contact us if you are in need of further assistance.
    shikar Friend
    #284678
    I have the same problem and used the solution mentioned here: change wmode to “transparant” but the problem remains. See: http://create2connect.nl/. I use template JA-Uvite, which works fine expect for this problem. Anybody an idea how to solve this? Thanks.
    Anonymous Moderator
    #284836
    hi shikar,
    I did not find this issue on your website.
    shikar Friend
    #284845
    Another forum member helped me with this. I had to set the wmode to “opaque” (not “transparent”) in the video plugin. That solved it. Thanks
This topic contains 11 replies, has 3 voices, and was last updated by  shikar 15 years, 11 months ago.
