  • jdponce Friend
    #131839
    I really can’t use this module, I understand this is a third part module, but I’m almost crazy with this.
    Well, I’m using Joomla 1.0.15, then, I downloaded the module for that version here:
    http://www.joomlart.com/forums/topic/all-videos-module-for-1-0/
    I think this link must be en download section, because was hard for me found it.
    Then, in other thread, hainn84 says we must install “all modules”, I don’t know what this means, because I only find one module. In case of joomla 1.5 there is a component not a module on official site of allvideo reloaded: http://allvideos.fritz-elfert.de/ in “download”, then, I don’t know what “all modules”.
    Well, but I intalled that module and I got the box media codes, and If I’m not wrong I set thie code I found here:
    http://allvideos.fritz-elfert.de/documentation/documentation-en-gb.html?start=2
    Then I wrote: {flv}cafeesaingles.flv{/flv} the flv file is in /images/stories/videos
    But I can’t see any video on my site!!! >:( http://www.consejocafe.org.
    Please tell me what is wrong in my precdure.
    Thanks in advance. :confused:
    jdponce Friend
    #264248
    Is this for allvideos module? 🙂
    #264253
    Sorry jdponce, that is wrong post for garciad
    I’m trying to fix allvideo for you
    Plz wait
    sbaldwin Friend
    #264257
    try changing {flv}cafeesaingles.flv{/flv} to: {flv}cafeesaingles{/flv} see if that helps…
    #264283
    Plz check your site
    I reinstall allvideo plugin by this attach ment
    2435
    then upload playlist.php to imagesstoriesvideos folder
    2436
    Then change in config of Video Café de El Salvador module
    from
    to
    jdponce Friend
    #264389
    I didn’t understand how to configure the playlist.php, with your help yes, thank you again. 😀
    #264391
    You only need to unzip playlist attach -> playlist.php, then copy to imagesstoriesvideos folder
    jdponce Friend
    #264429
    Ok thanks for all your help.
This topic contains 8 replies, has 3 voices, and was last updated by  jdponce 16 years, 4 months ago.
