  • rhisc Friend
    #122294
    Hi all,
    Moved within a couple of hours from Xenia II Shopping to Larix…
    See http://www.rhisc.nl but it seems we have a small problem with the JA News & Featured Product module.
    Must only be shown at the home page but it is shown everywhere?!
    Must be a deatil. JA news module and Featured mod are set to mainmenu-Home….
    We have to fix minor details like logo etc..
    Regards, Ronald
    mimitnt80 Friend
    #228042
    Hi, I have de same problem, someone to help us? Thx
    ErikThorsen Friend
    #228050
    Does the same happen if you unpublish for example the news module or the the featured product? That way you can narrow your problems down to either one of the modules or both of them. Unfortunately haven’t installed the Larix yet, so don’t know what might be up with this one.
    ErikThorsen Friend
    #228051
    Perhaps, could it be related to the JoomFish? Try to unpublish that one as well to see if that might solve something. Just unpublish all and then “republish” one by one to see which one is causing the problem. At least I would suspect it is Joomfish…
    rhisc Friend
    #228133
    When I set the JA VM Product slider also to only home. It looks it’s solved… but I want the slider on all… and feature products and JA news only on home I will check this weekend again..
    Update changed slider function to only home and later back to all… looks all is oke now…
    So home is with all three modules, rest like VM and content is now only with slider…. so Joomfish problem I don’t know.
This topic contains 5 replies, has 3 voices, and was last updated by  rhisc 17 years, 4 months ago.
