  • tfosnom Friend
    #176816
    @khoand
    Following your post here
    http://www.joomlart.com/forums/topic/place-ja-social-login-module-in-nex/
    I have downloaded and installed the mod ja login supplied. I have published this module to topmenu-right position in an attempt to get the ‘Login/Create An Account’ text next to the date. This is not happening, while the form displays near that area the text does not, nor does the form work, that is it does not do anything.
    Here’s a screenshot of what I’m attempting to do.
    If you have the time, I’d appreciate some advise and a solution, admin & ftp details attached for moderator access.
    For anyone following this thread site url is http://monsoftwebdesign.net/nex2
    Blessings Shannon
    1. login
    HeR0 Friend
    #452176
    Hi Tfosnom,
    I have fixed it on your site. Had a issue on mod_jalogin layout.
    Please check again.
    tfosnom Friend
    #452198
    Awesome Hung Phung! many thanks for the time you’ve spent. Can you look at the login panel and tell me what css file & location to edit to change the ‘Forgot your password” text etc. I need to change from white text to black?
    Cheers Shannon
    HeR0 Friend
    #452199
    Please look at /modules/mod_jalogin/assets/style.css
    Regards,
    tfosnom Friend
    #452209
    Hi Hung
    Thanks for your work, however neither form actually works. The login form when filled and prcessed returns a 404 error, the create an account form has an ‘must fill field ‘xyz’ which I have no clue what content belongs there so returns an invalid token when clicked is the xyz field there if I enable recaptcha?
    Also on the login form at text links (inactive) to password retrieval, these are only showing as a shadow text. looking in styles.css I can’t find the correct reference to that text, how do I get the text linking to relevent areas please?
    Blessings Shannon
    HeR0 Friend
    #452345
    You can see it in /nex2/templates/ja_nex/css/css3.css line 28
    text-shadow: 0 1px 1px rgba(0, 0, 0, 0.4);
    Hope that can help you.
    Regards,
    tfosnom Friend
    #452370
    Thanks for that but any idea on fixing the forms so they work? That’s the more important issue
    Shannon
    HeR0 Friend
    #452701
    Sorry, i did not understand, which form you are mentioning? Let me know, will help you out then
This topic contains 8 replies, has 2 voices, and was last updated by  HeR0 12 years, 7 months ago.
