  • wutangrob Friend
    #135511
    I installed the Ja-Nerine template on my computer, but It doesn’t work. In particolar the ja-slideshow. I read different posts and seen the video tutorial.
    – I use the last version of XAMPP for windows;
    – Joomla 1.5.8, legacy mode;
    I tried to understand, using the forum, if there was a solution but…anything…
    Someone can help me to understand because the ja-slideshow I use in Ja-Nerine don’t show the numbers slidebar like the demo site or for example this web site:
    http://www.geografica.org/janerine15/
    I notice the source code generated from the template in this site is different from mine:
    in my source code homepage don’t exist this line:
    – <div class=”ja-slideshow-mask”> </div>
    Is it a code problem or It’s a simple configuration problem?
    Hoping you can help me…Thanks in advance
    Roberto
    bennitos Friend
    #279680
    how did you install the template, did you use the quickstart?
    wutangrob Friend
    #279748
    First of all… Thanks!
    Regarding your question: yes…I just installed now, using the Quickstart! But It’s the same! In the linked picture you can watch the problem. If you need I can linked the code source…hoping you can help me…Ciao
    Roberto
    1. ja_nerine_on_my_Pc
This topic contains 3 replies, has 2 voices, and was last updated by  wutangrob 16 years, 1 month ago.
