  • timwu1616 Friend
    #166642
    Hello there,
    I installed the ja_teline_iv quick package and I don’t know how to use the Blog link located on the menu bar (most right side). When the mouse is over the link, an login form is popped up. The Using Joomla page (don’t know what it is though) is displayed after login. But if I just click on the Blog link ignore the login form , the blog page is displayed.
    Can anyone describe what the idea is here?
    Thank you.
    1. Google-Chrome-2
    #403075
    Hi timwu1616,
    Those menu items are in a second mega menu that displaying menu items from the topmega menu group, Do you want to modify this or anything else ?
    timwu1616 Friend
    #403165
    Hi dathq,
    It looks like there is some problem over there. The behavior of the menu bothers me. But I’ve change the installation from J16 back to j15 and it looks right for me then.
    Thank you very much.
This topic contains 3 replies, has 2 voices, and was last updated by  timwu1616 13 years, 5 months ago.
