  • mickael n. Friend
    #1023848
    Why the animations of certain style do not work on my website ?
    Like the style-5 of ace features in https://microbib-prelivre.com/resume/index.php/sigb/oxalys
    Thank you for the help
    Pankaj Sharma Moderator
    #1024128
    As I can see you are using JA ACM module from JA Uber template ACM files, in this case, some of the styles may not work, due to the template own design and animation in it.
    mickael n. Friend
    #1024285
    Hi thank you for the answer, but i have no solutions for that ? I can not keep the acm and the effect on the other template ?
    #1024380
    The ACM you are using is not JA Resume template. Each template ACM is designed for specific templates.
    You may use them but some feature/style may not work due to different template structures.
    mickael n. Friend
    #1025121
    Hi, can you help me for insert this effect in the acm module for ja resume please ?
    #1025200
    Hi @mickael n.
    This needs to look into js and php file and fall in personal custom work task.
    I can help you if there is any issue in the template package not working like demo. Adding custom style file for ACM does not behave exactly same that u can see in the template.
    mickael n. Friend
    #1025354
    Effects already exist and I use your templates and modules. You do not think to standardize your projects so that the effects work everywhere? Strange though …
    #1025361
    Its JA Resume template and all the module and style that comes with the JA Resume template will work on it. If there is any issue with template default style let me know. beside you can try to use the module style to xhtml from module options to load its own syle code.
    For the template animation style make sure that you have this page class enable-effect under Page Display tab under menu item of that page:
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 8 months ago.
