jhicks Friend
jhicks
- March 2011
- 12 times in 1 posts
May 1, 2012 at 12:51 pm #176629I’m sure I’m missing something simple but I cannot for the life of me get the masshead to work right.
This is what it looks like. This picture is the right size but it’s only showing the one little bar instead of the whole picture.
http://newhopemp.com/index.php/ministries/celebrate-recovery/latest-cr-news
Thank you.
Jeff
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
May 2, 2012 at 9:16 am #450991Hi Jhicks
I check on your site and see you somehow have lost height for ja-masshead block ( div.ja-masshead ), so it does not show full image background
Please set height ( css ) for it in template css file (/templates/ja_kranos/css/template.css):)
div.ja-masshead{
height: 250px;
}jhicks Friendjhicks
- March 2011
May 2, 2012 at 11:10 am #451023<em>@Hung Phung 317116 wrote:</em><blockquote>Hi Jhicks
div.ja-masshead{
height: 250px;
}</blockquote>I cannot find a reference in the template.css file for the ja-masshead at all. Are you saying I need to add that line? if so where cause I went back to the template I originally downloaded and it isn’t there either.
thank you,
Jeffjhicks Friendjhicks
- March 2011
May 2, 2012 at 2:05 pm #451051OK, I added the line to the css3.css and that made it taller but it does not expand to the sides at all. Please advise.
thanks,
Jeffhttp://newhopemp.com/index.php/ministries/celebrate-recovery/latest-cr-news
HeR0 FriendHeR0
- August 2011
May 4, 2012 at 3:24 am #451349Hi,
Please change
div.ja-masshead{
height: 250px;
}to
div.ja-masshead{
height: 250px;
background-position: center;
background-repeat: no-repeat;
}However, because it is background, so you should set a both height and width in css for div.ja-masshead block and resize image to that size before upload 🙂
jhicks Friendjhicks
- March 2011
May 9, 2012 at 4:41 pm #452247I will try this. For some reason I didn’t get and email showing you replied.
Thank you,
- March 2011
May 9, 2012 at 5:07 pm #452253ok, none of that worked. I found these lines in the template.css file
/* Masshead --- */
#ja-masshead .ja-masshead {
background-color: #fff !important;
color: #fff
height: 200px;
padding: 0 30px;
overflow: hidden;
}#ja-masshead .ja-masshead h3 {
color: #fff
font-size: 250%;
margin-top: 110px;
}#ja-masshead .ja-masshead .ja-masshead-desc {
font-size: 125%;
}#ja-masshead span {
background: url(../images/trans-black.png);
display: inline-block;
padding: 5px 10px;
line-height: 1;
}Is something wrong in this code?
thank again for your help,
- March 2011
May 15, 2012 at 2:20 pm #453147Anyone know what I’m doing wrong with the code?
zephyurhound2000 Friendzephyurhound2000
- November 2011
jhicks Friendjhicks
- March 2011
May 15, 2012 at 6:53 pm #453167<em>@zephyurhound2000 319878 wrote:</em><blockquote>I had this same problem, and it was because I had uninstalled the K2 component. Once I re-installed that component the Masshead worked properly again…</blockquote>
OK, I did that but now my slide shows do not work and the Mega Menu isn’t working. Do I need to do something special once K2 is installed to get back that functionality?
Thanks,
- March 2011
May 15, 2012 at 7:05 pm #453169OK, it was a jQuery problem. That has been corrected. I has caused the masshead to act.. differently now. I’ll keep pluggin away.
jhicks Friendjhicks
- March 2011
May 15, 2012 at 7:18 pm #453172FIXED!!!
It was back to the original suggestion. I had to increase the height.
thanks again all!
Jeff
- November 2011
May 15, 2012 at 7:35 pm #453174Yeah, I ran into the same issue with the front page, and I worked to fix it for some time until finally, I just exported out all my users/content in a database file. Did a clean install, and then re-imported my users/content. That fixed both the Masshead and the Slideshow issues. The problem really was a frustrating one. >:(
HeR0 FriendHeR0
- August 2011
impy2101 Friendimpy2101
- May 2012
May 22, 2012 at 1:34 am #454117Thanks, mine was missing also from the css3.css file. However, I would like my image to meet the menu at the top – I have a gap of about 1/2 inch or so. Is that a margin or padding?
AuthorPostsThis topic contains 40 replies, has 5 voices, and was last updated by HeR0 12 years, 1 month ago.
