lemick28 Friend
lemick28
- February 2013
March 1, 2017 at 4:07 am #1014319It appears that Ja_vintas is not compatible with the new version of Virtuemart since I have had to move Files from the New Virtuemarts Com_virtuemart into the Ja_vintas Com_virtuemart files. in order to get the Template to work.
Now I have another problem in that when running Ja_vintas template there is not "Custom attributes"
for example the buyer cannot select a specific color although I have those custom attributes set and they do appear when using Beez template as they should.
I have imported into the templates/ja_vintas/html/com_virtuemart/productdetails the file customfield.php which I took from Virtuemarts core files and renamed it "default_customfields.php". so the page loads (it would not without it) however it will not load the custom fields and shows the following errors:
Notice: Undefined variable: viewData in /home/lemick5/public_html/templates/ja_vintas/html/com_virtuemart/productdetails/default_customfields.php on line 15Notice: Undefined variable: viewData in /home/lemick5/public_html/templates/ja_vintas/html/com_virtuemart/productdetails/default_customfields.php on line 16
Which is the following 2 lines
$product = $viewData[‘product’];
$position = $viewData[‘position’];Thats it I have no idea where to go from there. Obviously Custom fields are Vital to my website.
can we please find a fix for this or maybe you have a newer version of your Virtuemart files for ja_vintas?
I am running the latest version of virtuemart.Here is a link to the product page with custom attributes:
http://www.lemickracing.com/index.php/shop/road-racing/brakes/master-cylinders/beringer-master-cylinders/beringer-br12-master-cylinder-detailObviously some Virtuemart files are missing but I dont know which ones they are.
I tried importing the Whole com_virtuemart file into Ja_vintas template to replace Ja_vintas com virtuemart which doesnt work.Saguaros ModeratorSaguaros
March 2, 2017 at 3:25 pm #1014791Hi,
As I can see that the color option custom field is showing on that product page, did you get it solved?
lemick28 Friendlemick28
- February 2013
March 2, 2017 at 7:17 pm #1014818Yes I solved it! only took about 12 hours of adding and removing files, testing the webpage over and over again until I found the combination that worked. and I’m not even sure how I got there. Virtuemart Forum would’nt help either because it was a Ja-vintas template issue.
This topic contains 2 replies, has 2 voices, and was last updated by lemick28 7 years, 8 months ago.
