  • ecliptech Friend
    #130383
    I have the same problem as a previous post where a secondary ‘View Cart’ button appears under the normal one.
    I removed the echo $saved_cart; line as advised in that post but this did not resolve the problem. The problem occurred in both IE and Firefox.
    My website url is http://www.ecliptech.com.au/ecliptech/
    Thanks in advance.
    Tony
    #257504
    Hi ecliptech !
    What virtuemart version do you use ?
    I think that this is a problem in view cart module of virtuemart 1.1.0 stable. You can try to fix it by way :
    Download Xenia ii package (at here) then use patch for virtuemart package to overwrite on your site.
    ecliptech Friend
    #257510
    I’m using virtuemart 1.1.0 stable. I applied the patch and it works perfectly. Thankyou. 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  ecliptech 16 years, 5 months ago.
