August 24, 2010 at 6:33 pm #153789
I was experimenting for a new look for my site with latest template from Rockettheme. They use Gantry framework whereas JA guys use T3 framework.
Now I am facing a very peculiar problem that all the earlier installed job board component and modules disappeared after I installed rockettheme template. When I try to re-install JA job board component, I get error message that this directory is already in use however I can not see the any of it in the back-end.
If somebody faced such a peculiar problem while installing gantry, then please do let me know so that I can take set about taking corrective measures on this part.
- 2008 times in 1700 posts
August 25, 2010 at 9:20 am #353642Hi,
My comments in blue
<em>@nishunb 191467 wrote:</em><blockquote>Hi
>> Please re-check the position of enabled module/component to clarify that they are supported by Rockettheme template or not.
Eg: If you enable JAJobBoardMenu Module at position = ‘left’ while Rockettheme template does not support ‘left’ position and that causes them to disappear.When I try to re-install JA job board component, I get error message that this directory is already in use however I can not see the any of it in the back-end.
>> Please re-check that those component/ Module are removed before installing another version or notIf somebody faced such a peculiar problem while installing gantry, then please do let me know so that I can take set about taking corrective measures on this part.
Thanks</blockquote>
August 25, 2010 at 10:29 am #353649Hi
Thanks for your reply. Please find my reply to your answer
1. I am simply not able to see the module in ‘Module manager’. This results in not being able to change the position at all.
2. As mentioned earlier, modules are not visible in ‘Module manager’ or for ‘Install/ Unistall’, I am not able to uninstall them at all.
Have you come across any such query before i.e. problem with JA job board when installed on Gantry framework. If you can offer some more insights as to why its happening, it will be very useful otherwise I will have to reisntall the whole thing again.:((
This topic contains 3 replies, has 2 voices, and was last updated by nishunb 14 years, 3 months ago.
