timtecsa Friend
timtecsa
- October 2009
- 132 times in 34 posts
December 9, 2015 at 4:56 pm #786422See uber-app demo You may notice that the App menu items are repeated as green buttons. See screen grab below. Also the the Search button is not showing and the Contact Us Address and Phone number should be in the yellow bar but are not visible.
Site is built from scratch without demo content. I used this version as reference, but have suspicion it is not up to date. http://uber.gpmnews.com/index.php
/Joomart/ images. Where can I get the full quota of demo images used in all Uber demo sites?
Saguaros ModeratorSaguaros
December 10, 2015 at 4:01 am #791303Hi Tim,
In the right menu, due to the concept of this Uber style, it will have only one menu item and we style so that it looks like green button. I think you use more than 1 item for this place so that all menu items have that ‘green button’.
Regarding to images, which images in demo of this Uber style you want to have? Thought that you can install quickstart with sample content in local site, all images are included there.
Cheers!!!
timtecsa Friendtimtecsa
- October 2009
December 11, 2015 at 1:42 am #800104I check back-end of your site, the contact us menu item is displaying a contact but in contact manager, there is no contact at all. Of course, it will show 404 page.
- October 2009
December 11, 2015 at 5:52 pm #805501Thanks. I think Uber is frying my brain 🙁 I’m still missing the Search module.
Rgds, Tim
P.S. And for some reason mouse button right click on this site (only) doesn’t work. Any idea why? I need to use Inspect Element to find out how to adjust the blue colour of the video to be more grey like here: http://www.aquafadas.com/en/
I fixed the video colour, more or less, but am still missing search button. The right click problem seems to have been a Chrome bug. Fixed itself on restart.
BTW. Why do I have a huge space between the contact form and the map module? How to remove? http://uber-app.gpmnews.com/index.php/app-contact
Fixed space with ‘no-padding’ class 🙂 Was ‘no-padding-bottom’ before
December 14, 2015 at 1:41 am #811665If there is any problem when using this template, kindly create a new Post. Community will help you out.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Saguaros 8 years, 11 months ago.
Application site menu duplication problem (and others)
