  • dlahiri Friend
    #159050
    Get the following error after applying JA Teline IV template (1.2.4) to my website:
    Fatal error: Cannot redeclare class JSMinException in /home/medhajo1/public_html/plugins/system/jat3/core/libs/jsmin.php on line 291
    URL:
    http://www.medhajournal.com/medha-reviews/movies-and-dvds.html
    http://www.medhajournal.com/site-map.html
    dlahiri Friend
    #373052
    <em>@dlahiri 216365 wrote:</em><blockquote>Hi,
    URL:
    http://www.medhajournal.com/site-map.html</blockquote>
    How do I open the support ticket associated with this problem? I am trying but am unable to open it. My JA login doesn’t work for the support site.
    Dwai
    #373131
    URL:
    Dear dlahiri,
    That means one of your extensions have a php class with the same name, it may be an plugin, you can try to disable one by one to find the one causing the conflict.
    Anonymous Moderator
    #373133
    <em>@dlahiri 216578 wrote:</em><blockquote>Hi,
    Dwai</blockquote>
    Your issue has been raised via ticketID#FHH-257-24642. In order to view it, please go http://support.joomlart.com and use your registered email and password to login this helpdesk system >> View all submitted tickets >> Find ticketID#FHH-257-24642
    kcdesi Friend
    #432501
    Was there ever a solution to this problem? If so, what was it. I’m seeing it too in my template. Almost one in three or four modules, or components is giving this issue. Yes, I’m avoiding it by disabling the component/module and I see no issue. I’m sure there has to be done something from the template’s side!
    Here’s a latest URL – http://www.kcdesi.com/new/index.php?option=com_gcalendar&view=gcalendar&Itemid=157 – this is currently an inactive menu item.
    dlahiri Friend
    #432545
    Yeah,
    I had a java script and css minimizer (forget the plugin name). Since Teline IV does the same thing, I had to turn off the old one and the site just worked fine after that.
This topic contains 6 replies, has 4 voices, and was last updated by  dlahiri 12 years, 11 months ago.
