  • kecomm Friend
    #946009
    In this closed thread it was announced that this would be fixed in the stable version:
    https://www.joomlart.com/forums/topic/how-to-use-the-apply-for-modules-box-in-modules-styles/
    It is still not working for me. I use [code]#Mod100[/code] but the style is not applied.
    Ninja Lead Moderator
    #946697
    So that I can take a look and try to assist, please provide the URL of the site and the screenshot of what did the problem on your site. I will help you to check this.
    kecomm Friend
    #946700
    kecomm Friend
    #946701
    #946703
    The video here will help you out.
    kecomm Friend
    #946990
    Thanks, but I did it exactly like in the video.
    #947153
    I tried to login backend of your site but it didn’t work, please help me to check it again.
    kecomm Friend
    #947211
    Sorry, I put it in the wrong usergroup. Now its SuperAdmin
    #947257
    It’s very strange with the problem on your site but you can try to use this way
    Open media/ja_simpli/css/custom-styles/13.css file and add new rule
    #Mod100, #Mod95{
        color: #f9f9f9;
        background-color: #1c76b2;
    Besides that, I will forward this bug to the development team to check the problem on your site.
    limma Friend
    #951243
    Hi, first of all I am very grateful to you for your beautiful template!
    I have the same problem with the custom style for modules.
    If I try to set them in the backend I can change only the background, but not the font color…
    I have also tried to insert this custom code into media/ja_simpli/css/custom-styles/9.css
    #Mod108, #Mod109, #Mod110{
            color: #ffffff;
            background-color: #7a1038;
    but no result.
    You can see the page here: http://dramsam.altervista.org/index.php/it/mostra-didattica
    and take a look to the three modules
    Bot-1 prova 1 Bot-1 prova 2 Bot-1 prova 3
    What can I do?
    Thanks in advance
    #951406
    @limma: Please have a look at my screenshot, you will see the background-color: #7a1038 has color like the main background and I change it to another parameter and it’s working as well
    1. Screen-Shot-2016-07-19-at-15.05.22
This topic contains 10 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 4 months ago.
