  • micahgweb Friend
    #174731
    Hello I have an issue with image alignment in my articles that I have isolated to JA Comment plugin. When I disable, then the images in all my articles display correctly as such:
    Otherwise the page looks like this:
    You can see the problem live here: http://hotflashnetwork.com/HotFlash-Central/what-is-a-hot-flash.html.
    You will notice that there is a big space to the left of the image and the text is not wrapping. Probably a simple fix but dont know where to look. Thanks for all your help.
    This is happening on all my articles across the board.
    Thanks,
    Stefano
    1. Correct
    2. Incorrect
    #443964
    Hi Stefano,
    You just open the file of templates/ja_seleni/css/template.css and add this css at it’s bottom
    .article-content span br{
    clear:none !important;
    That would help !
    micahgweb Friend
    #444041
    Hi Dat, that was definitely helpful in resolving the image alignment problem. However now, the JA comment plugin does not appear on any article page at all. I double check to make sure everything was set to enabled and it is. Any ideas why the comments would not be showing? Now I have removed the code you asked and now the comments are still not showing.
    Please let me know any information you need from me.
    Thanks.
    #444081
    Hi micahgweb,
    I am not sure of what you mentioned “the JA comment plugin does not appear on any article page at all”, I just checked and still I see the Ja comment appear on some article pages, example those pages
    http://hotflashnetwork.com/HotFlash-Central/the-hot-flash-culprit.html
    http://hotflashnetwork.com/HotFlash-Central/what-triggers-your-hot-flash.html
    if you want the ja comment to display under a menu item you just go to the Content – JA Comment setting, there in the field of Select menus you choose the menu items that you wish Ja comment appear on it.
    micahgweb Friend
    #445408
    Hi Dat, I believe we solved the problem. I actually used your suggestion but modified it to the following:
    .article-content br { clear:inherit !important; }
    Thanks again for all your support. Could not have done it without you.
    Be great….
This topic contains 5 replies, has 2 voices, and was last updated by  micahgweb 12 years, 9 months ago.
