Pankaj Sharma Moderator
September 21, 2016 at 3:05 am #969648Hi
Its the Joomla behaviour , when a category does not associate with a menu item , it will open the articles of this category on a Home page .
On your site, the category you selected in this module does not associate with any menu . Create a menu for example category blog and select the services category in it so when u click on the articles under this category , it will open under the menu you created .September 21, 2016 at 3:37 am #969658I created a menu and put our services in the menu type. Do I need to add each article as a menu Item. I have not done so. Still when I click on Pos 1 , 2, 3 readmore….just blinks and does not display article.
September 21, 2016 at 3:44 am #969662Hi
Kindly check the menu services you created and the template style you assigned for it .
The template style layout should have component block in its layout so show the output .September 21, 2016 at 4:08 am #969670I dont know where to check the template style associated. Could you explain.
September 21, 2016 at 4:34 am #969678This reply has been marked as private.September 21, 2016 at 4:43 am #969685This reply has been marked as private.September 21, 2016 at 4:45 am #969687This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
September 21, 2016 at 5:46 am #969698This reply has been marked as private.September 21, 2016 at 9:41 pm #969992I did everything you said. It worked for awhile today, but it’s back to not displaying the articles when you click on the links. Two actions were done that may have affected it.
- My partner went into an article with the editor on and it wiped out the http part of an address. I fixed that but it didn’t help.
- I tried to go into the layout and added 4 positions instead of 3 in the Our Services Section. I reserved this action thinking it may have caused the problem. I can’t imagine that would do it.
- I changed the title of Our Features to Our Services by editing an ini file.
So the problem is when I click on the readmore or title it just blinks and doesn’t display the article. I can’t figure what messed up.
September 22, 2016 at 3:29 am #970047Hi
The issue comes because you changed the template style of the services menu that i created .
The layout should be default for the default template style , it was feature intro i just changed it http://prntscr.com/ckvq49
Issue solved directly on your site , check it now ! -
This topic contains 11 replies, has 2 voices, and was last updated by cknowlan 8 years, 2 months ago.
The topic ‘Article blinks and does not display’ is closed to new replies.
