  • whouse Friend
    #177880
    I have my default home set up as blog category with Leading=1 Intro=2 Columns=2 Links=4. This is the default. Problem is that my intro articles, in 2 columns, have no space between them and it is difficult to separate where one ends and the other begins. Question is this: Where and what in which css file do I need to change in order to correct this?
    Link: knightsbaseball.net
    Any help is GREATLY appreciated!!!
    Thanks!
    #456459
    <em>@whouse 323955 wrote:</em><blockquote>I have my default home set up as blog category with Leading=1 Intro=2 Columns=2 Links=4. This is the default. Problem is that my intro articles, in 2 columns, have no space between them and it is difficult to separate where one ends and the other begins. Question is this: Where and what in which css file do I need to change in order to correct this?
    Thanks!</blockquote>
    you open the file of templates/your_template/css/template.css and adding this css
    .cols-2 .item {
    width: 49% !important;
    let me know if it help !
    whouse Friend
    #456525
    Yes, that gave about a 3-4 pixel separation between the columns. Thanks!
    whouse Friend
    #456552
    I spoke too soon. The articles are now running together again. I changed the order of display and now the lines between the two columns look like one big line. Looks horrible. Someone PLEASE help…
    #456583
    <em>@whouse 324206 wrote:</em><blockquote>I spoke too soon. The articles are now running together again. I changed the order of display and now the lines between the two columns look like one big line. Looks horrible. Someone PLEASE help…</blockquote>
    what you meant by “|changing the order” ? I took a look at your homepage now and I see the articles in one column instead of two columns as mentioned.
    whouse Friend
    #456687
    Yes, I changed it to 1 column because it was nearly unviewable with the intro articles in 2 columns. What I meant was that I re-ordered the articles. They were not in the correct order from first to last so I re-ordered them and that’s when I noticed the space was gone again. I will put it back to the 2 column layout this evening if you get a chance to look at it. You can email me at whouse @ gmail . com for a quick response if you need anything.
    Thanks for taking your time to help me. I greatly appreciate it.
    #456692
    <em>@whouse 324397 wrote:</em><blockquote>Yes, I changed it to 1 column because it was nearly unviewable with the intro articles in 2 columns. What I meant was that I re-ordered the articles. They were not in the correct order from first to last so I re-ordered them and that’s when I noticed the space was gone again. I will put it back to the 2 column layout this evening if you get a chance to look at it. You can email me at whouse @ gmail . com for a quick response if you need anything.
    Thanks for taking your time to help me. I greatly appreciate it.</blockquote>
    I just checked but did not see it in 2 columns as mentioned, you can pm me your admin account so I can check it myself to see the problem 🙂
    whouse Friend
    #456850
    Sorry for the delay. I was tied up with something else and didn’t get a chance to make the change or to post back here. Anyway, I am sending you a PM with admin details.
    Thanks for your help!
    #456891
    Hi whouse,
    you can try with this css
    .cols-2 .item {
    padding-right: 3px;
    I hope this would help !
    whouse Friend
    #456968
    Yes, that did it. Thanks so much for your time and help. I really appreciate it.
This topic contains 10 replies, has 2 voices, and was last updated by  whouse 12 years, 7 months ago.
