  • biljana_g Friend
    #143502
    I got problem with main column. Text in this column overlaping with text in left column. Here it’s a link >>>>
    Anonymous Moderator
    #315794
    Hi biljana_g
    I have tried to find your issue in IE7, IE8 and firefox but could not find.
    Did you fix it?
    biljana_g Friend
    #316528
    I reinstalled template. Now is better. thanks any way 🙂
    Anonymous Moderator
    #316785
    Hi biljana_g
    I am glad that all the issues have got fixed by now. I have marked your thread with Solved status. If you need further help, simply create a new thread so that our team could have a close look.
This topic contains 4 replies, has 2 voices, and was last updated by Anonymous 15 years, 3 months ago.
