  • asifak Friend
    #166872
    I have a article with an image at following menu;
    Home / Featured / Products
    When I click on ‘products’ menu then attached see the snapshot of the article where neither image nor discuss-comment plugin is working, that is no comments boxes are there. See attachment image-discus-1.png
    Then When I click the ‘comment(0)’ at the end of the article, then suddenly image of the article appears and discus-plugin also open its comment boxes. see attachment image-discus-2.png
    Interestingly, if the same article is available for instance at JA-New2, and if click on the title of the article then article open up with image and discuss-comment is working.
    1. image-discus-1
    2. image-discus-2
    chavan Friend
    #403758
    I don’t see the First image. I see only second article with comments. Please clear joomla clean cache and browser cache and check it again.
    asifak Friend
    #403781
    There is definitely a problem. I post my problems here in this forum after thorough test, even after clearing all cache and so. I am seeing this problem since many months.
    asifak Friend
    #403783
    It is JA Thumbnail plugin issue. When we disable ‘Thumbnail for Blog view’ under the parameters then it works ok, and image start to appear in the article. Now, i have disabled it.
This topic contains 4 replies, has 2 voices, and was last updated by  asifak 13 years, 5 months ago.
