  • linkwell Friend
    #1010139
    hello,
    I am using ja-uber and I want to have one introduction that is being used in the "About us" page. I market int he module that I want to show to be assigned at the menu itens that I want.
    In the menu itens, if I select the user-default the article shows up in the page, but not the intro. If I change the menu item to uber-home than I can see the intro that I want, but no article shows up.
    How to solve this?
    Thank you
    Hello
    The uber home layout is not using the component block ( where article can be showed ) it is using a special page blank content ( showing only modules ) to accomplish what you need you will need to create a custom-html module adding your article text and then publish it into your menu item that is using the home layout .
This topic contains 1 reply, has 2 voices, and was last updated by  pavit 7 years, 11 months ago.
