September 13, 2012 at 9:24 am #180662
Article page pagination problem on JA NEX theme.
when we click on pagination (Next) button then it goes to after 5 page.
what is the problem.
plz send me solution.
thanks
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
September 14, 2012 at 7:26 am #467006Hi Chronicle
I checked on our demo and could not find any problems.
Please check on http://www.joomlart.com/demo/#joomla25-templates.joomlart.com/ja_nex/Regards,
<em>@chronicle 338045 wrote:</em><blockquote>Article page pagination problem on JA NEX theme.when we click on pagination (Next) button then it goes to after 5 page.
thanks</blockquote>
September 14, 2012 at 11:15 am #467051Dear sir,
I have checked your demo and could not find any problems.
But in my site show problem .
Plz check my site http://prathampravakta.com/index.php?option=com_content&view=category&layout=blog&id=44&Itemid=125
thanks
HeR0 FriendHeR0
- August 2011
September 15, 2012 at 4:10 am #467088Hi Chronicle
Did you do any customization for the pagination function on your site which is resulted with errors from such customization. Please restore the configurations to default will help you avoid such issue.Regards,
September 15, 2012 at 9:56 am #467100Dear sir
I have not make any change in pagination function and not able to modify this plz suggest me how can i solve this problem.
my website is : http://prathampravakta.com/index.php?option=com_content&view=category&layout=blog&id=44&Itemid=125
thanks
HeR0 FriendHeR0
- August 2011
September 17, 2012 at 2:35 am #467154Hi Chronicle,
I am sure that pagination function is changed, the reason of this might be customization or install a new plugin ( or components ) which is affected to pagination method.
You should compare your site before this issue occurs to find out the solution. I think, the first you should disable some plugins which you just installed ( plugins can installed into your site when you install components )Regards,
September 26, 2012 at 9:18 am #468192Dear sir,
I am using joomla 1.5 and JA NEX theme.
In my website Category Blog Layout pagination gives error .how can i solve this please suggest me
i will really thankful to you.HeR0 FriendHeR0
- August 2011
September 26, 2012 at 10:01 am #468205Hi Chromicle
PM me ftp and admin account. I’ll help you resolved this issue.Regards,
<em>@chronicle 339785 wrote:</em><blockquote>Dear sir,I am using joomla 1.5 and JA NEX theme.
i will really thankful to you.</blockquote>HeR0 FriendHeR0
- August 2011
September 27, 2012 at 8:06 am #468344Hi
I clean all cache on your site. Here is the result http://prathampravakta.com/index.php?option=com_content&view=category&layout=blog&id=44&Itemid=125
So i thought the reason is cache. When you tried change somethings and forgot to clean cacheRegards,
September 27, 2012 at 11:39 am #468367Dear sir,
Problem is category blog layout pagination. please check this link through navigate this 2-3 page.
1st page is ok but after click on 2nd page or 3rd page then it goes to 6 page or blank.http://prathampravakta.com/index.php/2012-02-21-08-13-43/2012-02-21-08-25-01
Please check it again and send me solution.
your support is appreciateing and thankful.
thanks.
HeR0 FriendHeR0
- August 2011
October 2, 2012 at 7:47 am #468841Hi Chronicle
Pls update joomla to latest version. I checked several times, and there has not have any problem with template. So i doubt that the issue might be joomla pagination system. You can get a good developer from http://joomlancers.com to help you with this. . Please take backup all site before upgrading.Regards,
1 user says Thank You to HeR0 for this useful post
This topic contains 11 replies, has 2 voices, and was last updated by HeR0 12 years, 3 months ago.
