  • tabbus Friend
    #883717
    I’m getting many issues, when saving as a copy, any of the pre-formatted styles disappear when doing this.
    Nothing is played out the same or functions in the right way, I’ve switched off the editor but this has made no difference I’m still getting issues.
    I got this template as the layout and design was close to what I wanted, I thought with only a few minor changes I could get it up and running, but I’ve had more issues than I would have had if I’d designed it from scratch!
    Ninja Lead Moderator
    #883961
    You can rollback the changes you have done on your site and give me the URL of your site and a illustrated screenshot. It would help me to understand what you are trying to achieve and I would be able to help you better with specific answers.
    tabbus Friend
    #884434
    #885008
    About the problem bonus page on your site, because it doesn’t add " bonus-pages" CSS style in Page Class, see the screenshot
    Other the problem with Video Background, you can follow the step by user guide here and find 5. Video Background
    1. bonus_page
    tabbus Friend
    #885238
    Hello Thanks,
    I see, why isn’t this in the documentation? In fact I don’t find the documentation very extensive or helpful, some things like the modules have their own clear documentation, but when it comes to articles and classes with in the template, it’s very obscure, I spend most of the time cycling through settings just so I can figure out what has been used and then when duplicating it doesn’t duplicate properly, it cuts things out.
    The T3 template is very extensive and has many options but I find it very buggy compared with a standard joomla template set up.
    Where is there a listing of button and heading styles? I cannot find this at all, I see the typography page but it has no indication other than in the source body what they are, isn’t there a chart?
    Sorry for the rant but it has delayed my progress considerably compared to normal.
    #885953
    Don’t worry about this, if you have any further assistance, please don’t hesitate to contact us.
This topic contains 5 replies, has 2 voices, and was last updated by  Ninja Lead 8 years, 10 months ago.
