  • razum Friend
    #947951
    Hello! I have the same problem with the article scrolling in Google Chrome on windows with the mouse wheel. How to solve this problem? In addition, the demo version has the same problem!
    Hi @razum,
    We’re aware of this issue and the developer is checking it, you can check its status here: http://pm.joomlart.com/browse/JATCWALLJ25-645
    We’re sorry for any inconvenience it may cause.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 8 years, 4 months ago.
