  • Aratype Friend
    #170478
    Hi all,
    Again a RtL question: I wrote an article with an English word inside the Arabic title.
    The problem started in the back-end, adding this Latin word inverse the sentence wording:
    Back-end
    However, it appears correct in the home page:
    Home page:
    When I open the article:
    Article page:
    My question is how to add a bi-di support or RtL support to this?
    Thanking you in advance,
    Aratype
    Blaine Friend
    #424288
    Hi aratype!
    Please see if this Joomla.org thread helps you.
    Thanks!
    Aratype Friend
    #424483
    Thank you for the information. However I am afraid that this solution will inverse the template!
    I will see with Jean-Marie and tell you.
This topic contains 3 replies, has 2 voices, and was last updated by  Aratype 13 years, 1 month ago.
