  • ar2solutions Friend
    #158308
    hello forum,
    i’m getting this weird problem…
    i’ve already added many articles and the advance parameters of these articles are all set to “use global” (where you select to show title… author name… etc etc)… now if i change the global settings which is under content > article manager > parameters, to “title linkable” it doesn’t link the title!…
    but if i manually link the title by going under the article, it seems to work?!?!
    any suggestions to what the problem could be??
    houstonator Friend
    #370198
    Did you try option >> display from your menu items?
    1. title-linkable
    ar2solutions Friend
    #370343
    yes that seems to work!
    i changes the settings in the menu to global which fixed the problem.
    THANKS!
This topic contains 3 replies, has 2 voices, and was last updated by  ar2solutions 13 years, 11 months ago.
