  • hdavid90 Friend
    #965642
    Hi, the title of the article is not showing correctly in mobile device, is behind the logo. any idea how to fix it?
    Another question. Is ja slideshow compatible? I tried it, but is not responsive here. any layout or profile recommended? I need a small slideshow in the home page.
    @hdavid90
    Could you update the URL and login info so I can see the issue and check for you?
    hdavid90 Friend
    #965961
    Try opening the css file: ROOT/templates/ja-magz-ii/css/custom.css (create this file if it doesn’t exist)
    and add this css rule:
    @media (max-width: 360px) {
      .ja-slide-right {
        top: 50px;
    hdavid90 Friend
    #966095
    still the same, slide from homepage and titles from articles are hide by logo
    I updated it to:
      .ja-slide-right {
        top: 50px !important;
    You can have a look now.
    hdavid90 Friend
    #966267
    thanks, the homepage is fixed, but the title of the articles is still behind the logo, if you access to an article, for example any of the menu from "Servicios de credito" then you will see it (the problem is in mobile)
    I update the margin for page header in the file: /local/css/themes/cooperativa/template.css
    You can check it now
This topic contains 7 replies, has 2 voices, and was last updated by  Saguaros 8 years, 3 months ago.
