April 9, 2011 at 11:23 am #162567
hello. i’ve some problem with my site http://www.osservatoriesterni.it
(sorry for my english)
1) in the category/section the text iss too long. i want that all the boxes have the same size
2) i want that in these boxes the image have a border (where i’ve to set changes in css?
3) i want the colours of link that i’ve already read is not grey but always blue
thanks!!!
aman204 Friendaman204
- January 2010
- 418 times in 356 posts
April 9, 2011 at 5:12 pm #385548First, I would suggest you to please turn off css compression in template parameters to give in right file and line reference
1) You can try use this extension::
http://extensions.joomla.org/extensions/news-display/articles-summary/8503
which would add in feature for showing fixed intro text
April 9, 2011 at 5:27 pm #385550great!!!! tnx aman!
and for the colour of the link? do you think there is a solution?
i’ve another problem. the image in article is cropped but it is too small. how can i change this setting?
thanks!aman204 Friendaman204
- January 2010
April 9, 2011 at 5:44 pm #385553<em>@brucewoland 233167 wrote:</em><blockquote>great!!!! tnx aman!
thanks!</blockquote>1) Try add this at end of template.css file::
.blog-featured .article-content a{color:#003366;}
2) You can disable JA thumbnail plugin in plugin manager
April 9, 2011 at 7:38 pm #385562sorry, but the code doesn’t work. i attached an image for explain the problem. both the link have to be blue
2) with the plugin that you advised me the main article in home page is too short. there is a way to solve this problem too?
sorry for all these problem e thank you 🙂
- January 2010
April 10, 2011 at 6:07 am #385575<blockquote>First, I would suggest you to please turn off css compression in template parameters to give in right file and line reference</blockquote>
Please do this as suggested earlier
Also, The last screenshot illustration seems to move bit off the topic. Can you please ensure to have separate thread topic created for it
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by aman204 13 years, 9 months ago.
