May 14, 2013 at 12:17 pm #187479
Morning excuse the pessimo ingles!
Well I’m using and my JA_ZITE “ourblog” is not showing the images in front-hend (homepage) as model example could pass me the correct settings?
apararecem texts usually only those images are not loaded with textMay 14, 2013 at 12:57 pm #492706Ninja Lead ModeratorNinja Lead
- November 2014
- 3854 times in 3563 posts
May 15, 2013 at 11:25 am #492832As I can see from your description, i guess you are put image include in content of k2, that for reason image is not show this case. You can set the menu in home appear ja_zite, ja_zite_blog, ja_zite-static template of your site, the images will show.
Don’t forget to clear cache from Admin area after changing, let me know the result
May 15, 2013 at 8:02 pm #492886Ninja I already put confomer you can see in the picture below but still is not appearing images only text
- November 2014
May 16, 2013 at 7:31 am #492948In this case, I would need to take a closer look at your site. Please pm me URL of your site and admin access. I shall check it for you.
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by Ninja Lead 11 years, 4 months ago.
