Viewing 15 posts - 16 through 30 (of 35 total)
  • hdfilm Friend
    #257210
    <em>@questbg 63316 wrote:</em><blockquote>Ana … you certainly are onto something!! Thank you (‘thanked’ appropriately above)!
    OK, nearly there:
    1. Articles now going where they should
    2. Grey ‘stuff’ removed from top of page
    3. Double column layout is back!
    So, we only need to figure out whey the text is appearing underneath the image, and not alongside it, and I’m just about there.
    Nothing in the article code looks like it should cause this problem:
    So, if we can just crack that one, I’m done!
    Chris</blockquote>
    I see that you have the intro articles horizontal now.
    How did you get that?
    have read your posts here too, I got the big gray box away too, but still they are vertical beneath each other and not beside one of another like your screenshot here…
    So how did you fix that?
    Thank you in advance…
    questbg Friend
    #257245
    Hi hdfilm … can you send me site URL or screenshot so I can take a look?
    hdfilm Friend
    #257251
    <em>@questbg 63441 wrote:</em><blockquote>Hi hdfilm … can you send me site URL or screenshot so I can take a look?
    Thanks</blockquote>
    Here it is:
    http://www.filmtest.name/index.php?option=com_content&view=section&layout=blog&id=15&Itemid=265
    questbg Friend
    #257253
    Ah, this looks like a problem I had earlier.
    Please try to publish a ‘3rd’ new article into the section and see what happens?
    When I try this (along with Ana’s advice above re JAZin plugin update), then everything came good. I think you will need a 3rd article to test this!
    Good luck
    Chris
    hdfilm Friend
    #257258
    <em>@questbg 63449 wrote:</em><blockquote>Ah, this looks like a problem I had earlier.
    Good luck
    Chris</blockquote>
    It was kinda hitting me, having more articles… 😀
    Will do more articles and try it out 🙂
    Peace
    questbg Friend
    #257332
    Hi Ana
    <em>@anaivelisse 63387 wrote:</em><blockquote>Try this. It helped me with the same formatting problem.
    </blockquote>
    If I modify this code, will it not ‘force’ all images in articles to go left aligned?
    It’s just that we sometimes have right aligned images in articles.
    Day Four. Problem still exists
    So, here we are, four days later and still my 10th section will not work correctly. To recap where we are now:
    Site has 10 sections. 9 sections work perfectly, as per ‘demo’ site. 1 section does not. I have deleted and recreated the ’10th’ section three times, same problem every time.
    Articles published in the first 9 sections I created look like this:
    Same article published in my 10th section looks like this:
    So, we know this problem can not be ‘article’ related, it’s something attached to the Section/Categories. Trouble is, there is no evident code in the creation/modification of sections or categories that would ‘force’ articles to appear like this.
    Please, has anybody got any ideas?
    I have e-mailed JoomlArt customer support yesterday, but no response :((
    If no solution to this problem is found within the next 24 hours then I will have to throw in the towel with Teline II and move on…
    Chris
    #257343
    I’m checking your problem, maybe that is bug and i’m debugging. Please wait
    questbg Friend
    #257345
    <em>@nguoiabcd 63561 wrote:</em><blockquote>maybe that is bug and i’m debugging
    </blockquote>
    Thank you. Let me know if you need me to PM a ‘SuperAdmin’ password!
    swissvista Friend
    #257393
    Looks like Big Problem ! :confused:
    questbg Friend
    #257397
    <em>@swissvista 63620 wrote:</em><blockquote>Looks like Big Problem ! :confused:</blockquote>
    Yeah, I think so. It’s now over 6 hours since I sent SuperAdmin passwords to JA Mods. They have been in the site, but so far no fix.
    I can only think this is a bug in the code.
    As I said, if this is not fixed by 24.00 (CET) tonight, then I will stop all the work I’ve done with Teline II and switch templates. My site is now late for launch and I can’t demo to clients, so I have no choice but to go with a template that works.
    questbg Friend
    #257483
    Day Five … problem still not solved
    <em>@nguoiabcd 63561 wrote:</em><blockquote>I’m checking your problem, maybe that is bug and i’m debugging. Please wait</blockquote>
    It’s now 24 hours since JA took a look at the site and code and still no bug fix!
    So, if this is something that JA can’t fix … it’s certainly something I can’t fix, therefore, I can no longer continue with JA Teline II. Five days is too much time to waste on something like this.
    You would not believe how angry this makes me having created all the sections, categories, banners and around 35 articles … plus of course, I paid my ‘1 year’ money rather than my ‘3 month’ money as I believed I would receive full support during that period.
    Ah well, time to go find a magazine template that works.
    Thanks to all who helped me get as far as I did with the template … I hope you people carry on the fight and get the thing to work for your needs!
    Chris
    questbg Friend
    #257508
    OH. And if it makes any difference to anybody at JA. This morning I decided to ‘sacrifice’ one of my existing sections in order to make this work and save some of the work we’ve done so far.
    I took one of my sections and renamed it and renamed menu.
    I took the one category that was in this existing section and renamed it … and the menu.
    This works beautifully, just like it should … resizing the images, text wraparound, etc., etc. Just like it used to before I renamed it.
    So, I then need another 3 categories. I copy the existing one, which works fine. I rename the 3 new categories and the menu.
    What happens?
    The one category that already existed from the original demo works fine. The three ‘copies’ of this category have exactly the same problem as the Section/Categories I’ve been trying to create for five days.
    So, here’s how Section/Category1 looks:
    And, here’s how Section/Categories2/3+4 look:
    No company in the world can possibly work like this. :((
    It seems if I ‘modify’ a category that was in the original demo … everything works fine. If I add a new one, or even copy one, it all goes very wrong.
    What the hell kind of template is this? No support or feedback from JA, no help from the Developers and this appears to be a bug in their code … just great huh?
    Menalto Friend
    #257514
    <em>@questbg 63773 wrote:</em><blockquote>OH. And if it makes any difference to anybody at JA. This morning I decided to ‘sacrifice’ one of my existing sections in order to make this work and save some of the work we’ve done so far.
    What happens?
    >:( >:( >:(</blockquote>
    Just another day in paradise Chris
    If you look at the images you have there, will it help to make them smaller in width? So the text have a chance to wrap around them?
    questbg Friend
    #257517
    Hi Menalto
    <em>@Menalto 63779 wrote:</em><blockquote>Just another day in paradise Chris
    </blockquote>
    I wish! The place I’m in at the moment may be hot but it’s not paradise … it’s the place with the guy in the red cape with the horns!
    <em>@Menalto 63779 wrote:</em><blockquote>If you look at the images you have there, will it help to make them smaller in width? So the text have a chance to wrap around them?</blockquote>
    Nope. Already tried that:
    Also, I can take a story that works fine (no matter what size the images) in Category1 and copy this into Category2 and it doesn’t work (see images above)!
    In Cat1, the images are resized as set up for the category and the text wraps around. In Cat2 (even though this is a copy of Cat1), the result is a mess, no image resize, no runaround on image.
    To be honest, I’m getting really tired of the whole thing … maybe I’ll just continue with a printed product, at least I’m totally in control of that!!
    questbg Friend
    #257535
    Could I just say my absolute sincerest Thanks to Menalto … again! 😎
    He just PM’d me some code to place into one of the CSS files.
    Whilst this doesn’t fix the entire bug in the template (images not resizing, etc.), this has fixed my text runaround problem.
    This means, by changing all my images in these categories 100 pixels x 100 pixels wide at least I now have a workaround to the bug!
    Thanks to Menalto 😀
    … no thanks whatsoever to the JA team :((
    Don’t know why you guys continue solving their problems and doing their work without pay … you don’t seem to even get appropriate recognition for your help.
    Still, I’m extremely grateful!! 😎
This topic contains 35 replies, has 8 voices, and was last updated by  questbg 16 years, 6 months ago.
