  • wutangrob Friend
    #129611
    Hello Guys,
    why Ja-News doesn’t display all the content of articles I’ve published in homepage? In the back end, the option is set on public, but if I try to read an article, joomla tell me: you have to register if you want to read the content. If someone have a solution…
    Thanks in advance
    Roberto
    1) http://www.studioebau.com
    2) based installation + google map plugin + weblink plus+ janew module by joomlart
    3) 1.015 version
    4) I’ve just modify the header image and something in css.
    bye
    #253384
    Hi wutangrob !
    Please check again i think that you set article access is “Registered”. You can check it by way :
    Go to admin >> content >> all content –> view article which you can’t read then view access of that. view image attachment for detail.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years, 6 months ago.
