  • 7of9 Friend
    #204892
    I have a couple of problems:
    1. I get error: Notice: Undefined property: VirtueMartViewProductdetails::$askquestion_url in templates/ja_hawkstore/html/com_virtuemart/productdetails/default.php on line 32
    Is this why the ask questions is not shown?
    2. I added related products and they are not shown.
    Please advise.
    Thanks in advance.
    Adam M Moderator
    #564286
    Hi @7of9,
    I have just checked this matter and look like it’s a bug, please stay tuned while I’m investigating the issue and will reply back shortly with the solution.
    7of9 Friend
    #564364
    Thanks, I’m waiting.
    7of9 Friend
    #564489
    Hi @adam M ,
    Any news about that? Have you opened a ticket about this?
    Adam M Moderator
    #564620
    Hi @7of9,
    Not sue what you have changed in your site but I didn’t see the problem there anymore, could you please confirm your status ?
    7of9 Friend
    #564637
    Hi @adam M ,
    The problem remains, however in order to see the error you need to change the error level from Joomla; Global configuration, from System Default to Maximum.
    Also what about the problem of related products?
    Thanks in advance.
    Adam M Moderator
    #564792
    Hi @7of9,
    1. The option Maximum and Development is not a recommended setting for Error Reporting, normally just set it to use System Default, more detail can be found here.
    2. It’s a bug with Virtuemart 3 so you might have to wait for next update.
    7of9 Friend
    #564846
    Hi @adam M ,
    I don’t have the setting to maximum. I only set it for a while, in order to debug errors. In any case, this is what it is there for.
    Adam M Moderator
    #565038
    Hi @7of9,
    1. About the problem with error:
    please open file templates/ja_hawkstore/html/com_virtuemart/productdetails/default.php and look for this code :
    $.facebox({
    iframe: '" . $this->askquestion_url . "',
    rev: 'iframe|550|550'
    update as below :
    $.facebox({
    iframe: '" . $askquestion_url . "',
    then look for this line :
    $document = JFactory::getDocument();
    and update as below :
    $askquestion_url = JRoute::_('index.php?option=com_virtuemart&view=productdetails&task=askquestion&virtuemart_product_id=' . $this->product->virtuemart_product_id . '&virtuemart_category_id=' . $this->product->virtuemart_category_id . '&tmpl=component', FALSE);
    2. Another problem with Related Products, it’s a bug from Virtuemart 3 so you will have to wait for next update of Virtuemart as mentioned in my previous reply.
This topic contains 9 replies, has 2 voices, and was last updated by  Adam M 9 years, 9 months ago.
