kastoro Friend
kastoro
- May 2017
- 7 times in 6 posts
October 22, 2017 at 12:16 pm #1069338With Joomla 3.8.1. HTML5 audio don’t appear again. I make clear install and also what you suggest earlier (in /components/com_jamegafilter/assets/js/libs.js change
h: function(value) { return dust.escapeHtml(value); },
toh: function(value) { return value },
) but don’t work. http://www.refbudaors.hu/hanganyagok-kereso#sort=attr.ct7.frontend_value- This topic was modified 7 years, 1 month ago by kastoro.
- This topic was modified 7 years ago by kastoro. Reason: update problem
Mr.Cat ModeratorMr.Cat
- December 2016
- 53 times in 50 posts
October 23, 2017 at 2:40 am #1069411Here is solutions. 1 . Remove strip_tags function on helper.php
2 . On file
/plugins/jamegafilter/content/layouts/default/product-item.php
Replace {desc} for {desc|s}
If if it doesn’t work, please prove us site admin info for futher checking.
- This reply was modified 7 years, 1 month ago by Mr.Cat.
Wisdom is not a product of schooling but of the lifelong attempt to acquire it.
kastoro Friendkastoro
- May 2017
October 23, 2017 at 7:48 am #1069494This reply has been marked as private.Mr.Cat ModeratorMr.Cat
- December 2016
October 23, 2017 at 8:28 am #1069508I just replace this line on helper.php
$item->desc = !empty($baseItem->introtext) ? $this->getDesc($baseItem->introtext).'' : '';
With this line
$item->desc = $baseItem->introtext;
Make sure that you edited lib.js file.
P.S: You audio tag is auto preloading, it consumes bandwith a lot. Follow this to increase the preformance. https://stackoverflow.com/questions/11804129/how-to-prevent-html5-audio-from-predownload-streaming-on-load
- May 2017
- May 2017
November 3, 2017 at 2:08 pm #1072168I made update. Now my intro don’t appear. I can set only description. How can I get back intro text (audio)?
And how can I use the new cron function?
Thanks!Mr.Cat ModeratorMr.Cat
- December 2016
November 6, 2017 at 2:31 am #1072480In new update, we made some major on layout construction. You have to active field [description] to sho w it on frontend. Please follow the attachment below.
Try to download & reinstall JA Megafilter.
Then go to backend >> Page Option >> Drap & Drop Description to Front-end Display Elements.
You can follow this link for reference: https://www.joomlart.com/updates/ja-megafilter-released-with-5-stunning-new-features-and-bug-fixesAnd to show audio, find this line on file helper.php
$item->desc = $text ? $this->getDesc($text) : '';
with this line
1 user says Thank You to Mr.Cat for this useful post
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 6 replies, has 2 voices, and was last updated by Mr.Cat 7 years ago.
HTML5 Audio not work again
