  • rasada Friend
    #146958
    I have been using Teline with Joomla 1.0 – Now we are upgrading to Joomla 1.5 with Teline II.
    Using the plugin from http://www.jahoart.eu/ called Mini Mp3 player.
    The plugin works fine within the body copy but within the left module I cannot get it to work.
    Please let me know if you know of any issues or if you can have a look – the only other thing we have running is Virtumart – but even with all other modules switched off i seem to have a problem.
    Please advice – thanks
    rasada Friend
    #327007
    all solved – i got this from jahoart.eu
    Player in Modul is in Joomla 1.5x not directly possible.
    Alternatively, you can use the module “CustomContent” to the player show on a module position.
    -> http://extensions.joomla.org/component/option,com_mtree/task,viewlink/link_id,4175/Itemid,35/
This topic contains 2 replies, has 1 voice, and was last updated by  rasada 14 years, 11 months ago.
