December 9, 2008 at 3:43 am #281854
So, how does one accomplish this?
I tried playing around with the css file but it breaks the template…
gzellers Friendgzellers
- October 2008
- 3 times in 1 posts
December 9, 2008 at 5:03 pm #282031If someone can tell me the best way to explain it, I’ll try, lol. It was a while ago and I did a lot of trial and error to get it this way. I primarily edited the CSS file and created a suffix in order for the columns to go flush with the bottom.
scotty Friendscotty
- March 2008
- 827 times in 595 posts
December 9, 2008 at 6:53 pm #282038Fantastic looking site gzellers. Logo is 1st Class. Colours and styling are excellent. I bet the client was very happy!
Your bottom ad module (User5) background images seem to be too short, I’m seeing a brake in the grey frame on the left hand side. templates/ja_rutile/images/box-r-tr.gif and templates/ja_rutile/images/box-r-br.gif need to be a bit wider.
1 user says Thank You to scotty for this useful post
- October 2008
December 9, 2008 at 6:56 pm #282040Thank you for the kudos! I’m actually the client, designer and developer all wrapped into one. 🙂
I know the bottom ad module is broken and I plan on fixing that but it’s way down on my “to do” list. Thank you for the insight though as it really helps me shortcut where to look!
scotty Friendscotty
- March 2008
December 9, 2008 at 7:27 pm #282042Unzip to http://www.wombtobloom.com/templates/ja_rutile/images/
The zip contains both files extended to 1600px.
- October 2008
December 9, 2008 at 7:37 pm #282045Beautiful! Thanks so much. Looks good. 🙂
kicr Friendkicr
- June 2007
- 6 times in 1 posts
December 11, 2008 at 9:28 am #282326<em>@gzellers 94405 wrote:</em><blockquote>If someone can tell me the best way to explain it, I’ll try, lol. It was a while ago and I did a lot of trial and error to get it this way. I primarily edited the CSS file and created a suffix in order for the columns to go flush with the bottom.</blockquote>
So why don’t you publish css and index.php files? Then we can check what you’ve changed and try to write a short howto.
KiCR -
This topic contains 37 replies, has 11 voices, and was last updated by kicr 16 years ago.
