January 8, 2013 at 9:41 am #183756
Hi!
I am new to joomla and have a couple of problems:1. I would like to remove “Featured articles” area on the template (“introducing metro theme” on the demo) – How do I do it?
2. After removing the Mero Footer Logo (as described here on the forum) I am left with a black bar and a half Mero logo!
3. Probably the most important – the backend admin login is very slow – I cannot use thememagic and the Template layout is blank. I cannot change anything in the template.I am considering erasing the installation and starting again, but would really like to know what is wrong.
Thanks in advance!
Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
January 9, 2013 at 10:48 am #479068I will try to guide you work with it
1) Because homepage on your site is setting with Featured articles on menu site, it you need to remove it you have many change to config but you can try with my suggestion
<blockquote>ja_mero/css/themes/abstract/template.css</blockquote>
from
.blog-featured {
background: #fff
padding: 20px;
change to
.blog-featured {
background: #fff
padding: 20px;
display: none;
}2) Back to default on Footer Logo and change here
<blockquote>Open templates/ja_mero/css/template.css file</blockquote>
find and remove it
.copyright {
background: url('../../../images/themes/abstract/footer-logo.png') no-repeat left center;
3) For backend on JA Mero Template have been supported to config you can reference it here: http://demo.t3.joomlart.com/joomla30/documentation.html1 user says Thank You to Ninja Lead for this useful post
January 9, 2013 at 11:34 am #479076January 9, 2013 at 12:03 pm #479079Thanks Ninja – looks better – but I still have the black band along the bottom of the homepage.
Any ideas?
Ninja Lead
- November 2014
January 10, 2013 at 8:06 am #479219I have checked on your site but i could not duplicate the same your mention. I helped you to enable the footer, see the screenshot
January 10, 2013 at 11:11 am #479257Perfect! Thanks for the help!
itshugh 12 years ago.
