salvi70 Friend
salvi70
- August 2007
- 2 times in 1 posts
February 6, 2009 at 1:00 am #137838Hi!
I’m trying to install JA Quartz like the demo but there is an error occuring I can’t find the solution.
I downloaded and installed Quickinstall 1.5.
Then I did what’s explained on the install-guide in this forum.Everything is ok until it comes to the “highslide”-module.
When I open it (to configure it) the main menu in the backend disappears so that I can’t save, apply or do anything anymore.
And that’s it! The menu ist gone forever. Even if I close the window and try to log in again it doesn’t work because on the login-page I don’t see anything.. I can’t login anymore.I installed whole joomla about 5 times today trying to find out what it can be.
I even installed a “void” joomla-version and the template, modules and plugins afterwards. But the same error occurs every time. As soon as I open the highslide-module it’s “the end”! Menu lost and joomla not workable anymore.btw: the plugin was activated, of course.
So what can it be? Has anybody a similar or the same problem? Any solutions?
Thanks & Greetings!
February 6, 2009 at 1:04 am #289793same problem here hope i can get this to work would look good on my site..
salvi70 Friendsalvi70
- August 2007
February 6, 2009 at 9:28 am #289878@ admins
I have installed everything again now.
– joomla 1.5
– modules
– pluginsbut I haven’t configured anything, so you can go and look at it in the backend.
(I sent you login/passw. with my first post).thanks!
- August 2007
February 6, 2009 at 2:38 pm #289938to test i installed everything on joomla 1.0.15..
and it works!!but as I want a 1.5.-joomla-version the question keeps be open.
kansen Friendkansen
- September 2008
- 12 times in 1 posts
February 8, 2009 at 4:31 am #290075hi
i have almost the same problem, when i select type and try to save i got an error and cant save.
im using joomla 1.5.9
kansen Friendkansen
- September 2008
February 8, 2009 at 8:50 am #290081i found the way to make the template works ok, and it is using the quickstart installation, in the same way it install joomla 1.5.9
recomended to all.
cheers and good luck 😉
- August 2007
February 9, 2009 at 2:34 pm #290281as you can read on my first post i installed the quickstart inst. about 3-4 times and still have the same problem.
redserp Friendredserp
- May 2009
- 7 times in 1 posts
May 17, 2009 at 4:59 pm #304876hi,
go to phpMyAdmin and make a repair tables in the corresponding database.
Worked for me!
regards
😉1 user says Thank You to redserp for this useful post
June 4, 2009 at 4:04 pm #306914I have the same problem when I choose the type: slideshow controlbar or any other type I more do not succeed to save the module! I must leave in selec type in order seeing on the site the title it of the module
im using joomla 1.5.10
June 6, 2009 at 9:56 am #307130it is possible that nobody us aids? Nobody is successful to resolve the problem with joomla 1.5.10?
June 16, 2009 at 4:06 pm #308097<em>@salvi70 110180 wrote:</em><blockquote>Hi!
Thanks & Greetings!</blockquote>
same problem here, just clicking on the module in the backend is enough to make the backend menu disappear. need to do a re-install every time. Joomla Art are you listening ? don’t you think you owe the people here a solution ?
with me this problem occurs on a local server. This morning I tried it out on a remote server and editing ja highslide went without a hitch, no problem at all. So it might be the problem only occurs on local servers?
am using ff3, joomla 1.5.10, windows XP, Wamp
any ideas anyone ?
cheers
bertJune 18, 2009 at 8:01 am #308261Redserp – thanks for your tip. I had similar problem and the DB repair worked.
June 18, 2009 at 8:26 am #308262<em>@bertdewolff 132947 wrote:</em><blockquote>same problem here, just clicking on the module in the backend is enough to make the backend menu disappear. need to do a re-install every time. Joomla Art are you listening ? don’t you think you owe the people here a solution ?
any ideas anyone ?
cheers
bert</blockquote>the repair DB on local server did the trick for me too
thanks redserp for the tip and moosehead for bringing it up again
- May 2009
This topic contains 14 replies, has 7 voices, and was last updated by redserp 15 years, 6 months ago.
