  • mainorb Friend
    #181197
    I am trying to find out where are the settings for the background color for the articles and modules….
    I’ve changed the main background and I’ve set it to a background image.
    But now the text block (including the header) is transparent (as well as the menu’s). (see screenshot).
    I would like to set the whole block with content to white, change the article header color and give some color to the menu’s… could you guide me in the right direction?
    Thanks in advance!
    1. test
    Ninja Lead Moderator
    #469218
    Very difficult to give solution help you work right direction because your site is customized. You can use debug chrome and firefox browser to check about this add background color on the content, header…
    With original site:
    <blockquote>Open templates/ja_travel/css/template.css file</blockquote>
    #ja-mainbody {
    background: white;
    Please include URL and screenshot place you need to add background on your site here for further investigation. I will help you more accurate
    mainorb Friend
    #469333
    Thanks! this was what I was searching for… 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  mainorb 12 years, 1 month ago.
