May 26, 2015 at 3:14 pm #206646
I have set up two templates cl-default and cl-home. I have changed the background colour using theme magic from fff to f8fafc and it is not changing on the home page or any other site pages. I want the header that contains the logo to be white and the content page to be a bluey-grey so that the header is distinct from the content.
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
May 26, 2015 at 11:33 pm #571866Is there a particular page this is occurring on – because when I click on certain links on your site, some pages have the white header and off-white content area, and others don’t
TomC ModeratorTomC
- October 2014
May 26, 2015 at 11:33 pm #736911Is there a particular page this is occurring on – because when I click on certain links on your site, some pages have the white header and off-white content area, and others don’t
May 27, 2015 at 12:59 am #571879Tom hi, I am trying to have the top header that contains the logo as white and below that a light blue/grey. #f8fafc colour. I tried changing the background colour in the two templates that I am using: cl-home and cl-default. I have to say this is the most complicated template I have ever used and I have used a lot. We are rebranding from schoolclasslist.com to classlist.com and I decided to user uber for the rebranding to achieve a more modern look and feel. The template is so complicated I am starting to have second thoughts. I can’t even get footers to work on the site throughout and have given up and put them in the off-canvas menu which is not where I want them. I want the site to look fairly similar to what (schoolclasslist.com) I have but more modern and mobile responsive. Susan
May 27, 2015 at 12:59 am #736924Tom hi, I am trying to have the top header that contains the logo as white and below that a light blue/grey. #f8fafc colour. I tried changing the background colour in the two templates that I am using: cl-home and cl-default. I have to say this is the most complicated template I have ever used and I have used a lot. We are rebranding from schoolclasslist.com to classlist.com and I decided to user uber for the rebranding to achieve a more modern look and feel. The template is so complicated I am starting to have second thoughts. I can’t even get footers to work on the site throughout and have given up and put them in the off-canvas menu which is not where I want them. I want the site to look fairly similar to what (schoolclasslist.com) I have but more modern and mobile responsive. Susan
TomC ModeratorTomC
- October 2014
May 27, 2015 at 1:15 am #571883What browser are you looking at your site in?
I ask because when I look at your site (in Firefox), I am seeing your header as white (background) and the content area (background) as the #f8fafc color.
Perhaps if you could provide a screenshot of what you’re seeing – as a point of reference?
Maybe we’re seeing two different things … or maybe I’m not looking at the right thing(s). :((TomC ModeratorTomC
- October 2014
May 27, 2015 at 1:15 am #736928What browser are you looking at your site in?
Maybe we’re seeing two different things … or maybe I’m not looking at the right thing(s). :((May 27, 2015 at 12:25 pm #571963Here is an image of a typical page – . I see top bar with logo = white. Content below = white instead of #F8fafc. I am using firefox. I am assuming this is meant to be applying cl-default theme magic specifications.
TomC ModeratorTomC
- October 2014
May 27, 2015 at 11:33 pm #572092Try This . . . .
Within file path –> /templates/uber/local/css/off-canvas.css
at line 13, modify as follows:
.t3-wrapper {
background: #f8fafc none repeat scroll 0 0;
left: 0;
overflow: visible;
position: relative;
transition: transform 0.5s ease 0s;
z-index: 99;
}SAVE CHANGES – CLEAR CACHE – REFRESH PAGE
Better ??
TomC ModeratorTomC
- October 2014
May 27, 2015 at 11:33 pm #737132Try This . . . .
.t3-wrapper {
left: 0;
overflow: visible;
position: relative;
z-index: 99;
Better ??
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by TomC 9 years, 5 months ago.
Background colour is not changing in using theme magic
