Hey guys.
I have a slight problem with the background.
The best way to describe it is with some screenshots, so I’ll include some right now.
(taken at 1920×1080)
I have some text added to the image since I posted it on other forums as well.
As you can see the theme is slightly modified, but anyhow, to the problem..
(taken at 1280×1024 or 1024×768)
The problem should be pretty obvious, the background image (c-gb1.gif) which is just a slice of an image with 2 colors (you should be familiar with this technique) repeated on the y-axis and then aligned using “scroll=(x)%”.
However it misaligns when I decrease the size of my window.
My main container (site width) is 75% in these screenshots, and both navigation columns are 20% in width.
Now my suspicion is that is has something to do with the percentage-alignment of the page or the background.
Can you guys help me a bit here, maybe I should make c-bg1.gif match my site somehow, since it seems to work almost perfectly on the default ja purity theme (slight misalignment there as well).
