s4reea Friend
s4reea
- August 2013
- 2 times in 1 posts
September 5, 2013 at 10:00 am #190322Hello,
This is what i see in IE,And these are my settings:
phong nam Friend
phong nam
- May 2015
- 974 times in 888 posts
September 6, 2013 at 7:08 am #504822Hi s4reea,
You just need to turn off the Development Mode after finishing your customization task. Your website will display fine on IE then.
As you know, the IE needs immediately the compiled .css files of template to display the website’s front-end layout while the Compile Less to Css process lasts at least 10s to finish. That is why the T3 templates don’t display fine on IE when the Development Mode is turned on.
1 user says Thank You to phong nam for this useful post
s4reea Friends4reea
- August 2013
September 6, 2013 at 1:29 pm #504881Thanks a lot,
You are truly a good supporter.
The problem consisted with my IE browser but i tested it with IE browser tester online and found that everything is ok now.
Thanks again. -
Viewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by s4reea 11 years, 3 months ago.
