  • glennbmx7 Friend
    #129209
    Ive been working on my joomla 1.5 website (http://www.urge21.net) and have been having trouble with the banner position not showing the headline image. So if anyone can help with that thad be great!
    Also how do you add a custom background image for module???
    And lastly I have no idea how to get rid of the image that says “Lates videos & Photos”.
    I want it to only show up on the home page but it shows up on all of them. its the “h3-bg-hilite.png image.
    Thanks for any help!
    Glenn
    #251676
    Hi glennbmx7 !
    About remove “Lates videos & Photos” image you open template.css file in templates/ja_helio/css/ folder . then find following code section at about line 913 :
    #ja-pathway {
    background:transparent url(../images/h3-bg-hilite.png) no-repeat scroll right center;
    display:block;
    float:left;
    height:30px;
    margin:0pt;
    padding:0pt;
    width:100%;
    change into :
    #ja-pathway {
    display:block;
    float:left;
    height:30px;
    margin:0pt;
    padding:0pt;
    width:100%;
    about banner position . i do’nt show that problem ,Please send short screen .
    glennbmx7 Friend
    #251724
    Thanks a bunch for the help! 🙂
    Now if you take a look at my site, you will see that the “Poll” Module is in the (Banner) position but will not display the header image like the other positions do.
    Thanks!
    #251802
    Hi glennbmx7 !
    I think that Poll module You don’t set for it show title of module. View image attachment for detail :
    glennbmx7 Friend
    #251921
    the “Show Title” is selected!
    I think is has to do with the module coding???
    #252039
    Hi glennbmx7 !
    Please send admin information via pm , I will check it for you !
This topic contains 6 replies, has 2 voices, and was last updated by  Sherlock 16 years, 7 months ago.
