  • jana1 Friend
    #134039
    If I activate the banner module in the position top, you can see only half of the banner. The rest is hidden behind the cart.
    http://img125.imageshack.us/img125/2805/basl7.gif
    How can I solve this problem?
    I use Joomla 1.5.7 with Ja Mesolite Quickstart.
    lcristian Friend
    #273863
    This is not a problem.
    It’s the way that template was designed.
    Consult the MODULES GUIDE
    I see 2 ways of getting your banner to show full.
    1. Publish it in the Ja Products Slide position
    2. Hack the VM Currency module and increase its width, move the position.
    Good luck
    jana1 Friend
    #273960
    Thank you very much for your answer.
    I did it, and it works. FANTASTIC!
    But how can I delete the separator line between Currency module and Cart module??
    shertmann Friend
    #274017
    must edit the following line of code in template.css
    #ja-vmcurrency {
    width: 300px;
    position: absolute;
    top: 20px;
    right: 230px;
    height: 65px;
    border-right: 1px solid #E6E6E6;
    the red bolded line of code is the css style that defines that separator line delete it or coment it
    jana1 Friend
    #274025
    Thanky you very much.
    shertmann Friend
    #274031
    it was a pleasure
This topic contains 6 replies, has 3 voices, and was last updated by  shertmann 16 years, 2 months ago.
